llData 10.51 Full Complete - Domestic/Asian/Europe
3Q2011 | 02.2012 | EN | Win All | 48xDVD9 | iSZ | ~269 GB
Alldata contains a full description of repair and maintenance for cars of American manufacture, as well as Asian and European vehicle production produced for the American market. Alldata 10.51 will help to repair not only American cars, but it will renovate and European and Asian foreign cars, since many nodes in the cars are identical, despite the assembly for different markets. The program provides detailed information on repair, which describes the features of the device separate mechanisms, norms of various parameters (volumes of refueling capacities, wheel alignment, etc.), the diagnostic and repair equipment and special tools, the description of works on assembly, disassembly, adjustment, repair and diagnostics, information about the location of components and tools, etc.
The program Alldata 10.51, you can not only repair but also to engage in troubleshooting electronic components car. To do this, you have the following information: location of the diagnostic connector, detailed tables decoding fault codes indicating the possible causes, symptoms, and the consistency checks to fix the problem, description of the read blocks of current parameters with an indication of normative values, work with channel adaptation, etc . This version is the portable version and can be run from an external hard drive, unlike the previous version of this Alldata 10.51 added more drives, now the total number of 48 disk.
AllData 10.51
• The most comprehensive information for 1982 to present vehicles, updated quarterly
• OEM images, diagrams and diagnostic flow charts
• Parts and labor information
• Maintenance schedules
• Manufacturer TSBs and Recalls
• Integrated estimating software
• OEM wiring diagrams with connector, ground, power distribution and splice information
• A2Z Component Search - the fastest route available to component information
Automotive repair shops that use the ALLDATA 10.51 system have a clear differentiation from other repair facilities. ALLDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures. ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services. Moreover, ALLDATA helps shops build consumer confidence and loyalty.
AllData 10.51 Contents List:
Daignosis and Repair
All Diagnostic Trouble Codes(DTC)
Relays and Modules
Sensors and Switches
Maintenance
Engine, Cooling and Exhaust
Powertrain Management
Transmission and Drivetrain
Brakes and Traction Control
Starting and Charging
Power and Ground Distribution
Steering and Suspension
Heating and Air Conditioning
Restraint Systems
Accessories and Optional Equipment
Body and Frame
Cruise Control
Instrument Panel, Gauses and Warning Indicators
Lighting and Horns
Windows and Glass
Wiper and Washer Systems
Parts and Labour
Popular Information
Diagnostic Trouble Codes DTC
Technical Service Bulletins
Specifications
Locations
Diagrams
Service Precautions
Technician Safety Information
Vehicle Damage Warnings
Vehicle Identification
Tools and Equipment
System Diagnosis
Five-Step Troubleshooting
Troubleshooting Precautions
Troubleshooting Tests
General Troubleshooting
Power Relay Test
AllData 10.51 Models List:
- USA (Domestic 1-10)
- Model's 1960-1981 (Emission 2002)
- Asian (Import 1-19)
- Europe (Import 20-37)
Full list of models available on each disc (total 48 disc's), also look in the archives AllData.10.50_48xDVD_How.to.Install_Run.From.HD_Manual.Info.rar and/or in the txt-file ALLDATA_3Q2011_Full_Complect_DVD_Contain.txt. These files are on each file-exchanger in the section Download.
Install notes:
- Place all ISZ-image files in one folder on your hard drive (eg.: AllData.10.50);
- Before you install, carefully examine the installation instructions! All the detailed instructions found in the archives AllData.10.50_48xDVD_How.to.Install_Run.From.HD_Manual.Info.rar and AllData_10.50_3Q11_Install-Updates-Fixes_Cr4ck.rar.
1. Burn or mount the Image AllData_10.50_3Q11_Install-Updates-Fixes_Cr4ck or AllData.10.50_Install_Disk with your favorite Tool (se bottom **).
2. Start Setup and install.
3. After installation is complete, copy the files from Crack-folder in a folder with a installed program's.
4. Enjoy!
** Alcohol 120%, DAEMON Tools or UltraISO - the best Tools for mount or convert and burn ISZ-images
*** The archive Support_Utilities contain more tools, patches and fixes for some crash bugs.
this is it
ad 10. 51.rar
ad 10. 51.rar
