jackhoo
Информация о jackhoo
557 просмотров профиля
Достижения jackhoo
  1. If your volvo car go wrong,you can look at this: http://www.youtube.com/watch?v=W08ET5Qp4oI&list=UUcDlEIO2ofzx5ipMZBgH3sg&index=1 have some question,everyone can discuss follow
  2. http://www.obd365.com/wholesale/obd2-dtc-reader-mt-50.html Thanks fukntsii diagnostic OBD-2 tracker NAVIXY A2 time you can learn about the problems in the car, and even about what systems require repair. Regarding the Lamp "Motor fault" and DTC-error codes displayed on a special widget in the Web-interface monitoring system. Using this information and reference error code (easy to find on the Internet), you can find out which node is faulty and how serious it is. So, for the above example, the error codes DTC indicate malfunction in the ignition system of the engine: P0300 - cylinder firing out of order P0302 - Disturbed 2 cylinder firing order P0305 - Violated 5 cylinder firing order P0420 - Too low catalyst productivity (bank 1) P0430 - Too low catalyst productivity (bank 2)
  3. http://www.careucar.com/wholesale/porsche-piwis-tester-ii.html Porsche Piwis Tester II with CF-30 Laptop Kindly note: 1.Update via CD or HDD.It's one year free, after one year is 200usd/time. 2.We can offer you online programming, it will charge 200usd/time.This will be done by our tech people via remote control. Porsche Piwis Tester II Function: 1. Read/clear error code, catch data stream, computer programming match, component test, maintenance information consult, components site drawing, wiring diagram. 2. Porsche Piwis Tester II works with the old and latest Porsche cars. It is equipped with the Panasonic laptop and original software for the test. Porsche Piwis Tester II can help you diagnose and program the most new and old kind of Porsche cars. For example: 911(997)(991), Boxster/Cayman, (987), Cayenne up to MY 2010, Cayenne from MY 2011 and Panamera. 3. New Panamera can only be diagnosed by using Porsche Piwis Tester II. Based on current project planning, all earlier vehicle models will gradually be changed over to the new Porsche Piwis Tester II by the end of 2010. Porsche Piwis Tester I must be used for older models in the Porsche workshop until end of 2010. 4. Support for Porsche Piwis Tester I will no longer be available once the earlier diagnostic programs have been transferred to Porsche Piwis Tester II. 5. When Porsche Piwis Tester II is distributed, it will contain one basic piece of software. This is necessary in order to start and configure the tester. Porsche Piwis Tester II Support Systems ENGINE automatio transmission, air-conditioner, SRS, ABS, ASR, MPL, GM, Original antitheft System,KEYLESS GO system, OBDII system. Porsche Piwis Tester II Vehicle Coverage 1. 911(997) (991) 2. Boxster/Cayman (987) 3. Cayenne up to MY 2010 4. Cayenne from MY 2011 5. Panamera Porsche Piwis Tester II Package Including: 1. Piwis Tester II VCI * 1 PCs 2. OBDII Cable *2 PCs 3. USB Cable * 1 PCs 4. Extensional Cable *2 PCs 5. Used CF-30 FAQ: Q: How to accomplish Porsche Piwis Tester II online function? A: Porsche Piwis Tester II online is via Team Viewer remote control, globally available. Q: How to handle with 90 days locking about Porsche Piwis Tester II? A: Porsche Piwis Tester II timing is unlimited, always showing 90 days. Q: How much software update charges for per year? A: The first year software update fee is free. Q: How to update software? A: By CD or HDD. Q: What is the current software version for Porsche Piwis Tester II? A: Version V13.400. Covers Porsche's vehicle lists to the whole year of 2013's. Q: If License area showing China or CN? A: The License Area does not show China or CN. Q: If there is manual available? A: Yes. Provide electronic English manual for free. Please e-mail us to obtain it. Q: What types of computers are available for Porsche Piwis Tester II? A: Used CF-30 laptop. Q: If it is showing Porsche Logo when booting computer? A: Yes, CF-30 are with Porsche Logo when booting computer. Q: What languages are available for Porsche Piwis Tester II? A: Language availability: German, British English, American English, French, Italian, Spanish,Japanese, Chinese, Russian, Portuguese, and Dutch. Q: License Validity? A: To support ONLINE function, valid certificate must be available for Porsche Piwis Tester II. Requires ONLINE modules: (F BCM R BCM DME ELV SRS KEY) Software Display:
  4. http://www.careucar.com/wholesale/renault-can-clip-diagnostic-interface-a.html 2014 Best Quality Renault CAN Clip OBD2 Diagnostic Interface This is best quality one. More stable on diagnosis. It's very simple to diagnose a vehicle using Renault CAN Clip Diagnostic Interface: just select the vehicle make, enter the V.I.N. and press ENTER. Renault new update software version: V139 Renault Clip Functions: 1. See all the information relating to the vehicle 2. Computer test 3. Automatic test of all computers 4. Reprogramming 5. Airbag test 6. Scan tool (OBD tests) 7. Base Doc (access to Technical Notes) 8. Physical measurements 9. Antipollution 10. Multimeter Renault Can Clip V139 Supported Languages: English,German,Brazil,Denish,Spanish,Finnish,French,Italian,Norwegian,Dutch,Portuguese,Romania,Swedish. Packing Including: 1pc x Renault can clip Main unit 1pc x OBDII Cable 1pc x Renault 12pin Cable 1pc x USB Cable 1pc x CD software 32CM*19CM*9CM Renault CAN Clip Registration steps: 1. After finish Installation, DO NOT run your CLiP! 2. Copy the RSRwin.ext to C:\CLIP_X91\Lib\Application\ 3. Then run your CLIP, choose "Register me now" and in the next Windows, please select "NO"! 4. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
  5. http://www.careucar.com/wholesale/lexia-3-pp2000-citroen-peugeot-diagnostic-tool-with-diagbox-d.html Lexia-3 Lexia3 V47.99 PP2000 V25 Citroen/Peugeot Diagnostic with Diagbox V6.01 Software Best Price PP2000/LEXIA-3 Interface works for both Citroen and Peugeot! Diagbox V6.01 Software free provide in the CD. Update: by CD LEXIA-3/PP2000 Description: 1. It is compatible with Citroen cars including: C1,C2,C3,C4,C6,C8,C-CROSSER,NEMO,BERLINGO,JUMPY,JUMPER,AX,SAXO,BX and so on. But please pay attention, according to our customer's experience, this item can not works good at C5 new models. 2. It is compatible with most Peugeot cars from 1995..If you have the two types of cars, please pay attention, please check with us first before purchase. 3. Diagnostics is performed via OBD-II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001). LEXIA-3/PP2000 Function: Unlike other universal car scanner tools which only read fault codes; this software performs nearly ALL the functions like the original dealer diagnostic tool. Our diagnostic interface contains K-Line multiplexor, CAN-BUS interfaces and SAE J1850 bus (both PWM and VPW). 1. Read identification Displays complete identification of control unit, e.g. part number, software/hardware version, manufacturer, etc... 2. Read fault codes Displays all stored and pending fault codes with complete description (e.g. "Rail pressure - too low pressure"). Program supports report printing or copy to clipboard. 3. Clear fault codes this function clears all stored fault codes and other diagnostic information. 4. Auto-scan (complete car scan/test) Detects all ECUs (electronic control units) installed in car and reads all diagnostic fault codes. 5. Measured Values Program displays live Data like Engine Speed, Battery voltage, Oxygen Sensor, Coolant Temperature, etc. Values can be displayed in graph, 9 values at once, or full listing (all measured values). Logging to file is also supported, which allows offline analysis. 6. Actuator test Actuator test activates particular actuator (e.g. turn on fuel pump, lock/unlock wheel, lock/unlock doors, cut off fuel, etc..)
  6. http://www.careucar.com/wholesale/tuirel-s777-auto-diagnostic-tool-with-full-software.html Tuirel S777 Retail DIY Professional Hand-held Auto Scanner Get Tuirel S777 for Reasons: 1.Tuirel S777 comes with total 46 car softwares 2.Multi-languages supported:English/ Spanish/ Portuguese/ Serbian/ Farsi/German/ Italian/Swidish/ Arabic/ French/ Greece/ Deutch/ Korean/Czech/ Russian/ Turkish/ Japanese 3.Tuirel S777 support update online. Tuirel S777 Vehicle Coverage: Austford, Audi, Benz, BMW, Chrysler, Daewoo, Daihatsu, Euroford, Fiat, GM, Holden, Honda, Hyundai,Jpisuzu, Kia, Lancia, LandRover, Maruti, Suzuki, Mazda, Mitsubishi, Nissan, OPEL, Perodua, Peugeot, Porsche, Proton, Renault, Vauxhall, Romeo, Rover,Demo, Saab, Skoda, Smart,Toyota, USAFord, Volvo, VW, Jaguar, Mahindra , Citroen,OBDII,OPEL, Seat, Sprinter, Ssangyong,Subaru. Tuirel S777 Features: 1. Read and clear codes on ALL electronic systems. 2. Vehicles before 1996 can be diagnosed. 3. Faster and stable diagnostic speed with unique new platform. 4. High frequency of update up to professional auto diagnostic tools 5. High definition touch display provides high sensitivity with screen locking/unlocking function. 6. Capture, save and print screenshots for convenient troubleshooting. 7. Support mass storage SD card. 8. Compact and attractive housing with protective rubber case makes it more durable and impact-free. Tuirel S777 Functions: 1. Communication test of CAN-BUS and K communication cable. Support following protocols: PWM, VPW, KWP2000, ISO9141, CAN-BUS 2. Basic Function: 1) Read ECU information 2) Read trouble code 3) Clear trouble code 4) Read DataStream 5) Component test
