maniken
Участник-
4 -
Информация о maniken
- День рождения 18.11.1985
Автомобиль
s8,q7
Пол
Город
Vilnius
Интересы
очень уский профил:оптика авто
214 просмотров профиля
Достижения maniken
VIN: WAUZZZ4E37N005582 License Plate: Mileage: 132760km-82493mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 66 69 72 76 77 VIN: WAUZZZ4E37N005582 Mileage: 132760km/82493miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: Malfunction 0010 65-Tire Pressure -- Status: Malfunction 0010 66-Seat, Rear -- Status: Cannot be reached 1100 69-Trailer -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI Є0060 Revision: 5AH11--- Serial number: AUX3Z0F6399963 Coding: 01060003190F0160 Shop #: WSC 05460 995 89693 VCID: DFCDC5FE0E9D11E64D9-808A 6 Faults Found: 008212 - Intake Manifold Flap Position Sensor (Bank 1) P2014 - 002 - Electrical Malfunction Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:06:21 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 68.0°C Temperature: 30.0°C Absolute Pres.: 980.0 mbar Voltage: 12.446 V 000275 - Intake Air Temp. Sensor (G42) P0113 - 002 - Signal too High - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:14 Freeze Frame: RPM: 1067 /min Load: 19.2 % Speed: 0.0 km/h Temperature: 90.0°C Temperature: -40.0°C Absolute Pres.: 980.0 mbar Voltage: 11.557 V 000258 - Mass Air Flow Sensor (G70) P0102 - 002 - Signal too Low - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Freeze Frame: RPM: 1237 /min Load: 24.3 % Speed: 0.0 km/h Temperature: 90.0°C Temperature: -40.0°C Absolute Pres.: 980.0 mbar Voltage: 11.811 V 005634 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0°C Temperature: -40.0°C Absolute Pres.: 0.0 mbar Voltage: 0.000 V 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:37 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 68.0°C Temperature: 30.0°C Absolute Pres.: 980.0 mbar Voltage: 12.446 V 005715 - Please check DTC Memory of ABS Controller P1653 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:37 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 68.0°C Temperature: 30.0°C Absolute Pres.: 980.0 mbar Voltage: 12.446 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 K HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0089229 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2B55E12E8AA53D46111-807E 1 Fault Found: 006231 - Load Signal P1857 - 001 - Error Message from ECU - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:19 Freeze Frame: RPM: 800 /min RPM: 768 /min RPM: 0 /min (no units): 30.0 (no units): 36.0 Temperature: 47.0°C T.B. Angle: 0.0° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H46 0500 Coding: 0001627 Shop #: WSC 05460 000 00000 VCID: 24470A12E77BF23ED0B-8071 2 Faults Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F6399963 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: D8BFEEE26BB3E6DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 24470A12E77BF23ED0B-8071 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 731 G HW: 4E0 035 729 A Component: Interfacebox H43 2830 Revision: 00000000 Serial number: 300GU067569816 Coding: 0000012 Shop #: WSC 02313 785 00200 VCID: 25411716EC410B36C75-8070 Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH03 0040 Subsystem 2 - Serial number: 00000000015198 Subsystem 3 - Serial number: 0113.07.060000000100010211я Subsystem 4 - Serial number: 010211я No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000102428 Coding: 0041081 Shop #: WSC 02311 785 00200 VCID: 1C3732F2DF0BCAFE68B-8049 4 Faults Found: 00819 - High Pressure Sensor (G65) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 191 Mileage: 132768 km Time Indication: 0 Date: 2014.04.21 Time: 13:12:05 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 191 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:13 Freeze Frame: Bin. Bits: 00011111 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 191 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:52 Freeze Frame: Voltage: 12.90 V 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 191 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:52 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 3663C05A41E770AE7EF-8063 Subsystem 1 - Part No: 4E1 910 113 B Component: Wischer WWS D3 H50 0400 Coding: 00000035 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 00141886 Shop #: WSC 02313 5 Faults Found: 00908 - Control Module for Wiper Motor 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 30 Reset counter: 192 Mileage: 0 km Time Indication: 0 01494 - Bulb for Parking Lamps; Left (M1) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:36 01498 - Bulb for Parking Lamps; Right (M3) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:37 01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:38 01500 - Bulb for Fog-Lamps; Right (L23) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:38 ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI Є0060 Revision: 5AH11--- Serial number: AUX3Z0F6399963 Coding: 01060003190F0160 Shop #: WSC 05460 995 89693 VCID: DFCDC5FE0E9D11E64D9-808A 4 Faults Found: 005715 - Please check DTC Memory of ABS Controller P1653 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:05:24 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 68.0°C Temperature: 30.0°C Absolute Pres.: 980.0 mbar Voltage: 12.319 V 008199 - Intake Manifold Flap; Bank 2 P2007 - 008 - Stuck Closed - Intermittent Freeze Frame: Fault Status: 00111000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:05:27 Freeze Frame: RPM: 647 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 74.0°C Temperature: 28.0°C Absolute Pres.: 980.0 mbar Voltage: 14.097 V 008197 - Intake Manifold Flap; Bank 2 P2005 - 002 - Stuck Open - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:05:29 Freeze Frame: RPM: 646 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 74.0°C Temperature: 28.0°C Absolute Pres.: 980.0 mbar Voltage: 13.970 V 005634 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0°C Temperature: -40.0°C Absolute Pres.: 0.0 mbar Voltage: 0.000 V ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H13 3710 Revision: 91H13371 Serial number: 0037P000P6K0 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275D1D1E964D1926F59-8072 Subsystem 1 - Serial number: 63328RB401641D39F Subsystem 2 - Serial number: 63428RB401641D65F Subsystem 3 - Serial number: 63528RB401641D95J Subsystem 4 - Serial number: 63628RB401641DBFW Subsystem 5 - Serial number: 63729RB40079030AC Subsystem 6 - Serial number: 63829RB4016B796BZ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksдulenmodul H14 0040 Coding: 0012141 Shop #: WSC 02311 785 00200 VCID: E5C1D7162CC14B36875-80B0 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 901 D HW: 4E0 920 901 D Component: KOMBIINSTR. VDO H82 0520 Revision: D03 Serial number: AUDID3F6000148 Coding: 0048103 Shop #: WSC 02680 995 194823 VCID: 21490306F869E716BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 20003066238091 Coding: FDFFFFFD2B3504 Shop #: WSC 00012 123 12345 VCID: 275D1D1E964D1926F59-8072 1 Fault Found: 00462 - Control Module for Seat Memory; Rear (J522) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:03 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E1 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 26072006192631 Shop #: WSC 00000 000 00000 VCID: 1F4D05FECE1DD1E68D9-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBF8162089 Shop #: WSC 00000 000 00000 VCID: 1C3732F2DF0BCAFE68B-8049 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F6399963 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: D8BFEEE26BB3E6DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 C Component: KLIMA-STG. FOND 017 0230 Revision: 00000019 Serial number: 00000000043879 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: E1C9C30638E927167BD-80B4 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2A5BE42A855F244EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 24470A12E77BF23ED0B-8071 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D Component: MNS ECE H48 0850 Revision: 00000000 Serial number: 364GT067580380 Shop #: WSC 05460 995 65361 VCID: 3B75D16E7AC5ADC6811-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000620000015 Coding: 0003284 Shop #: WSC 02313 785 00200 VCID: 1D313FF6C411C3F69F5-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 801 B Component: Tьrsteuer.FS BRM003 0100 Coding: 0028461 Shop #: WSC 02313 785 00200 VCID: 204F0602F363EE1EB43-8075 5 Faults Found: 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 0 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 0 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 0 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 192 Mileage: 132768 km Time Indication: 0 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 192 Mileage: 132768 km Time Indication: 0 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H07 0010 Revision: 00100007 Serial number: W040607240188 Coding: 0004712 Shop #: WSC 02313 785 00200 VCID: 2A5BE42A855F244EEA7-807F Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 A HW: 4E0 035 466 Component: BO_D3 H06 0170 Revision: 12S00002 Serial number: 02106060003677 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 24470A12E77BF23ED0B-8071 Subsystem 1 - Part No: 4E0 910 465 A Component: BO_D3_SLAVE H31 0100 Subsystem 2 - Serial number: 01107060001919 Subsystem 3 - Serial number: 0211.07.060000000100030011я Subsystem 4 - Serial number: 030011я No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000001058 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E3338FAC917D8EE86F-804B 2 Faults Found: 02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:00 02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:16:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 B Component: Tьrsteuer.BF BRM003 0100 Coding: 0028461 Shop #: WSC 02313 785 00200 VCID: 204F0602F363EE1EB43-8075 5 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 132768 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 0 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 0 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 192 Mileage: 132768 km Time Indication: 0 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 192 Mileage: 132768 km Time Indication: 0 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000731 Shop #: WSC 08660 995 103799 VCID: 1F4D05FECE1DD1E68D9-804A 2 Faults Found: 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 192 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: Voltage: 12.21 V Count: 41 02432 - Supply Voltage for Left Parking Brake Motor (V282) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11111100 Fault Priority: 1 Fault Frequency: 2 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:12 Freeze Frame: Voltage: 12.42 V Count: 86 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 29591B2680592F56E3D-807C Subsystem 1 - Part No: NOSUBSYSTEM Component: AFS-Modul links Subsystem 2 - Part No: NOSUBSYSTEM Component: AFS-Modul rechts 1 Fault Found: 02071 - Local Databus 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 152 Mileage: 132776 km Time Indication: 0 Date: 2014.04.22 Time: 00:09:28 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 M HW: 4E0 035 541 P Component: TUNER EU/US/RDW H42 0570 Revision: 00000000 Serial number: 396G%067543596 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2A5BE42A855F244EEA7-807F 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 251 Reset counter: 192 Mileage: 122831 km Time Indication: 0 Date: 2013.07.05 Time: 15:44:18 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 A HW: 4E0 919 148 Component: R0078 TVhybridTuner 0280 Revision: R0H05000 Serial number: 76300700458101 Coding: 0000005 Shop #: WSC 02313 785 00200 VCID: 21490306F869E716BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000013893 Shop #: WSC 05460 995 65361 VCID: 204F0602F363EE1EB43-8075 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2607200420 Coding: 344530393135313035412056413032363037323030343230 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Tьrsteuer.HL BRM003 0100 Coding: 0028461 Shop #: WSC 02313 785 00200 VCID: 1E3338FAC917D8EE86F-804B 5 Faults Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 132768 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 192 Mileage: 0 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 192 Mileage: 132768 km Time Indication: 0 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 192 Mileage: 132768 km Time Indication: 0 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000900046836 Coding: 0212428 Shop #: WSC 02313 785 00200 VCID: 204F0602F363EE1EB43-8075 1 Fault Found: 01521 - Sensor for Tire Pressure 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 12 Reset counter: 0 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:08:59 Freeze Frame: (no units): 0.0 Temperature: 25.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 66: Seat, Rear Cannot be reached ------------------------------------------------------------------------------- Address 69: Trailer Labels: 4E0-910-383.lbl Part No SW: 4E0 910 383 C HW: 4E0 907 383 C Component: ANHAENGERELEKTR 004 0060 Coding: 0001001 Shop #: WSC 02313 785 00200 VCID: 24470A12E77BF23ED0B-8071 5 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 10 Reset counter: 192 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 02:48:00 02564 - Trailer; Left Tail Lamps (M60) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:00 02566 - Trailer; Left Turn Signals (M62) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 152 Mileage: 0 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:00 02565 - Trailer; Right Turn Signals (M63) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 152 Mileage: 0 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:00 02562 - Trailer; Brake Lamps 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 152 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:00:00 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Tьrsteuer.HR BRM003 0100 Coding: 0028461 Shop #: WSC 02313 785 00200 VCID: 1E3338FAC917D8EE86F-804B No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08720619401503 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 2345090EE275F506A91-8076 1 Fault Found: 02069 - Front Parking Aid Sensors 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 153 Mileage: 132768 km Time Indication: 0 Date: 2014.04.22 Time: 00:12:03 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 C Component: TELEFONMODUL EU 0770 Revision: 00000008 Serial number: T2AUDX0806JNMT Coding: 0000004 Shop #: WSC 02313 785 00200 VCID: 224B0C0AFD6FFC0EA27-8077 No fault code found. End --------------------------------------------------------------------- лог старый,снимал как толко приехала битая,тепер ошибок нет,пару осталось совсем не актуалных
vas 5054a,vag12.12,willem 4 pro
привет,не нахожу нечево на audi s8 5.2FSI ... ,может кто из ребят могбы помочь само собой не безплатно.а то в диапазоне 500км обратитса не к кому.
