elecautocr
Информация о elecautocr
    VW Golf
1 576 просмотров профиля
Достижения elecautocr
  1. Hello www23: Can you help me with immo off file for Siena ME7.9.6 0261 208 410 ? Thanks very much 29F400 orignal.rar
  2. Hello members: I am looking for original file GreatWall Wingle 2008 2.8TDI EDC16C39-6.H1, part number 0281013328 software number 538699 Thanks
  3. hello members: I am looking for pinout connectio to read&write TCU unit of Hyundai/Kia MEG17.9.12 mcu ST10F275 using boot mode and K-line. I dont see K-line on ecu diagram, only CAN-lines, but my ecu is bad and can-lines are dead. I need to try to read in boot mode by kline. Thanks!!
  4. Hello members: I need to delete DTC P0748 AND recalculate checksumm on Kia Rio transmission mcu ST10F275 inside MEG17.9.12. Can someone do this job? TUB2C14G10_H3064201-20220621-082726.rar
  5. Hello members: I need to delete DTC P0606 in Nissan Kicks 1.6L gasoline mcu is R7F70125. Do any of you can do it ? Original file is here: Original file Thanks
  6. Hello flesher: I have the same situation, I need to install used ESCL (unknow donor vin) Did you solve the problem ? Did you get the password from the stm8af dump ? Thanks
  7. Hello friends: I need to read Mack MP8 truck ECU, is TRW EMS, I think is EMS2, but not sure. MCU is MPC5554 Do any of you have BDM conection for this ECU ? or is possible to read by J1708 ? thanks very much
  8. Hola amigos Chevrolet Spark = Daewoo Matiz 2001, 0.8 L, el error P0601 (suma de comprobación) está presente. La ECU es Siemens (creo que Fenix5M) K115444001C 96291048 con 28F512. ¿Tiene reparación o reparación? ** Este carro no es equipo con inmovilizador ** Spark 800cc 2001 Siemens 2R K115444001c 96291048 28F512 original.rar
  9. Hello members: I have 2009 1.6L Hyudai Accent A/T, car does not start, error code is P0605 Internal control module read only memory error. Can someone of you can check if checksum is correct and fix it ? Thanks very much for your help.
  10. elecautocr
    Nissan Versa 2007 Immo-off
    Hello members: I need to disable Nats on Nissan Versa 2007 1.8L gasoline MT USA version. Mcu is 70F58. I am attaching original ECU file Do any of you can do it ? Thanks very much
  11. Hello members: I am working in 2007 Suzuki Swift 1.3L gasoline This car is not equipment with immobilizer system, but after low -battery event , the car doesn´t start, and DTC P1638 is present (P1638 = immobilizer information mismatched) I think the eeprom file of ECU is damage, or maybe mcu flash is damage I am attaching the original eeprom ECU file. Do you have a good dump for this ECU or can you repair the dump ?? ECU number is 33921-73KJ0 eeprom 9356 mcu 7055 Thanks very much Swift 2007 13L MT nacional ECU 33921-73KJ0 S93A56A original.rar
