achaccha
Информация о achaccha
Достижения achaccha
  1. your file is not recognized by my software, can you please read at 16 bit? regards
  2. Dear Friends. I am looking for a BCM2 editor. I especially need to edit the 16 Bytes of CS, I also need to edit the power class. Can you recommend an editor please? Probe Tango but only part of the CS is displayed. thanks for your help
  3. Дорогой друг, я из Перу в Южной Америке, я говорю по-испански, но могу писать на любом языке благодаря Google Пожалуйста, мне нужна ваша помощь, я хочу выполнить сопряжение ЭБУ SID208 с блоком BSI 95640 Peugeot Boxer. Буду признателен, если вы подготовите файл для записи в ЭБУ или иммо. Большое спасибо за Вашу помощь
  4. Good morning friends Please I need your help, I want to pair the SID208 ecu with 95640 BSI the Peugeot Boxer . I would appreciate if you can prepare the file to write. thank you very much for your help BOXER SID208 HELP ME.rar
  5. Dear Friends. I need the complete diagram for Suzuki S-Cross from the year 2017 ECU 33910-61M00 0261S08263 New Immo 37171-61M00 used. Also I will need if someone can provide me with a KIT of files for ecu and Immo. I have to rebuild a vehicle that was totally dismantled. thanks for your help
  6. I have had a similar problem after a vehicle accident. the problem is just a blown fuse. I hope you can check all the fuses including the ones next to the battery
  7. I suggest first a diagnosis to the mechanical part of the engine. Measure engine compression and check injectors. It is the most common for this type of failure, defective injector or low engine compression to occur. a hug
  8. I suggest doing virgin: Ecu ID code, Certification Ecu, steering lock. program a blank key with teachstream and then pair the engine ecu by jumpering pin 4 and pin 13 of the OBD2 connector. regards
  9. Dear Friends. I need your help to clone this 2016 Nissan Xtrail ecu. Please can you tell me with which tool can I do this reading? ecuflasher supports this ecu? thanks for your help
  10. I recently subscribed to this prestigious Forum, I will try to share my knowledge with all the members and how I also want to learn from you. thanks for accepting my participation
