Пенко выслал:hc(9)08
if you read AD AD you need security bytes.
Conections
DO NOT REMOVE THE CHIP FROM TARGET BOARD
READ THE CHIP IN CIRCUIT
Make connections as described in attached picture
Click auto baud button, if this action fail you have connections problem
/ but in some chips auto baud may not work, in this case you have to set baud rate manual
Set Baud rate manual (correct baud rate your can calculate according device datasheet - monitor section) /
If no sucess
Lift/Cut IRQ, PTA0, and reset pins, solder the wires from the programmer direct to MCU pins
Power target board by external power supply (in most cases 12V DC); do not make connection to Vdd(chip) - P9(programmer)
After Autobaud / unsucess reading make power up reset - remove powerfrom the chip and wait until Vdd
Regards
Penko Kovatchev
> Security bytes for some boards
> 68HC08AZ32A 4L52H
> $DA-$AC-$E5-$2C-$E5-$2C-$E5-$2C
> Renault Kangoo 2006
> mc68hc908AZ48A 1L02M
> $F9-$F1-$F9-$F4-$F9-$F7-$F9-$FA
> Renault Laguna 2004 Year
> MC68HC(9)08AZ32
> Mask nr: 0J66D
> Sec.Bit : F9-F1-F9-F4-F9-F7-F9-FA
> Fiat Scudo -2003.08
> MC68HC(9)08AZ32A
> Mask nr : 0J66D
> Sec.Bit : 9F-9C-F6-98-F6-98-F6-98
> Fiat Scudo 2003.09-2004.08
> MC68HC(9)08AZ32A
> Mask nr: 0L52H
> Sec.Bit : 9F-A4-F6-E0-F6-E0-F6-E0
> Fiat Scudo 2004.09-
> MC68HC(9)08AZ48A
> Mask nr: 1L02M
> Sec.Bit : A7-05-A6-58-A6-58-A6-55
> Vag airbag
> mc68hc908AZ60 8H62A ????
> Sec.Bit: F9-F1-F9-F4-F9-F7-F9-FA
> Dash A 000 446 73 21 M.M. 0905 005 9901
> HC08AZ32A MASK: L52H
> BD 57 BD 57 BD 57 BD 54
> Laguna: =MC68HC908AZ60A(3K85K)
> Mercedes E 211 Rear SAM 2J74Y
> SS = $E5 $DD $E4 $0A $67 $2B $E5 $DD
> Ford Explorer 2002 Module 4X4CM 3J74Y
> SS = $DC $A0 $DC $93 $E1 $24 $DC $A0
> VW51 AIRBAG unit
> 1C0 909 601 - 5wk43120
> MC68HC08AZ32 (2L52H)
> $BE-$07-$BD-$57-$BD-$57-$BD-$54
> $FF-$FF-$FF-$FF-$FF-$FF-$FF-$FF=MC68HC908AS60A
> (1L87J)
> $F9-$F1-$F9-$F4-$F9-$F7-$F9-$FA=MC68HC908AZ60A
> (3K85K)
> $BE-$07-$BD-$57-$BD-$57-$BD-$54=MC68HC08 (2L52H)
> $E0-$A6-$B1-$24-$B1-$24-$E0-$A6=MC68HC08 (2L52H)
$00-$00-$00-$00-$00-$00-$00-$00=MC68HC908AZ60(Default)
> $10-$0C-$10-$09-$10-$06-$10-$03=MC68HC908AZ60(2J74Y)
> $11-$11-$11-$11-$11-$11-$11-$11=MC68HC908AZ60(2J74Y)
> $22-$22-$22-$22-$22-$22-$22-$22=MC68HC908AZ60(2J74Y)
> $46-$FF-$8E-$00-$49-$E2-$8E-$00=MC68HC908AZ60(2J74Y)
> $49-$50-$59-$BB-$0D-$02-$08-$82=MC68HC908AZ60(2J74Y)
> $86-$C9-$86-$C9-$86-$C9-$86-$C9=MC68HC908AZ60(2J74Y)
> $AA-$08-$AA-$08-$A9-$94-$AA-$08=MC68HC908AZ60(2J74Y)
> $BC-$B8-$C8-$06-$C8-$06-$C8-$06=MC68HC908AZ60(2J74Y)
> $E5-$78-$EE-$F9-$EE-$F9-$EE-$F9=MC68HC908AZ60(2J74Y)
> $E5-$DD-$E4-$0A-$67-$2B-$E5-$DD=MC68HC908AZ60(2J74Y)
> $E5-$E3-$E4-$10-$67-$2B-$E5-$E3=MC68HC908AZ60(2J74Y)
> $F8-$F2-$F9-$F3-$F9-$F5-$F9-$F7=MC68HC908AZ60(2J74Y)
> $F9-$F1-$F9-$F4-$F9-$F7-$F9-$FA=MC68HC908AZ60(2J74Y)
$FF-$FF-$FF-$FF-$FF-$FF-$FF-$FF=MC68HC908AZ60A(Default)
