megaw
    2
Весь контент megaw
  1. А вот завтра свой 1.4 и пытну))) благо здесь есть файл восстановления покойного)))
  2. Вот опись: V3.6 Features and Specifications Diagnostic via CAN and Special functions via K-line. Covers all electronic control units in vehicles (diagnostic addresses from 0x01 to 0x80). This can allow of user to investigate and diagnosis some new units untouchable for remaining diagnostic tools. Functions are under CAN-TP2.0. Manual definition of running diagnostic session not like remaining diagnostic tools always standard diagnostic session 0x89. Function is under CAN-TP2.0. Broadcast diagnostic request disable normal communication, clear DTCs, Logistic (transport) mode,.... Functions are under CAN-TP2.0. Allows managing of brand new units (and immobilizer units) where is allowed programming of PIN, SKC, BGW, MAC. Functions are under CAN-TP2.0. Most of popular diagnostic requests identifications, coding, adaptations, DTCs and s.o. Functions are under CAN-TP2.0. Special function - odometer correction in instrument clusters and EDC15x. Special function - read Security Access Code/Login WFS. Special function - read/program immobilizer data. Special function - read/write EEPROM from instrument cluster/immobilizer. All supported clusters CAN/K. Special function - VAG MMI TV Activation. Special function - Read/Write EEPROM of Engine Control Units BOSCH VAG-EDC15x, VAG-ME7.1.1, VAG-Cartronic ME7.8,Porsche. Special function - Key learning buttons for easy usage (not needed security code). Can do component security authorization. Special function - Key learning Porsche CAYENNE (not needed security code) K+CAN. Special function - Custom memory reading from different units like ECUs, EZS-Kessy and s.o.. Special function - Reading flash memories EDC16x, EDC15x, ME7x, MED951, MED751 (with next update will be possible programming of flash memories Special function - Crash data clear in airbag units List of vehicles covered from function odometer change via OBDII: Audi Q7 (CAN) Audi A2 (K) Audi A3 (CAN) up to 2007 !!! Audi A3 VDO/M73 up to 2003 (K) Audi A4 VDO/M73 (K) Audi A4 BOSCH - RB4 clusters (CRYPTO eeproms R/W by OBDII) Audi A6 VDO (K) Audi A6 (CAN) Audi Allroud (K) up to 2004 Audi A8 (K) VDO93xx Audi A8 (CAN) up to 2007 !!! Audi TT (K) Seat Alhambra (K) Seat Altea (CAN) Seat Arosa (K) Seat Cordoba after 1999 (K) Seat Ibiza VDO after 1999 (K) Seat Leon (K+CAN) Seat Toledo (K+CAN) Skoda Octavia (K) Skoda Octavia II (CAN) Skoda Superb (K) Skoda Roomster (K) Skoda Scout (CAN) Skoda Fabia (K) VW Bora (K) VW Beetle (K) VW Caddy (CAN) VW EOS (CAN) VW Golf4 VDO/Motometer/BOSCH RB VW Golf5 VDO (CAN) VW Golf5 VISETEON VW Crossgolf (CAN) VW Individual (CAN) VW Jetta (K+CAN) VW Passat B5/B6 (K+CAN) VW Polo VDO/Motometer (K) VW Sharan (K) VW T4/T5 VDO (K) VW Touaran VDO (CAN) List of vehicles covered from function security access code/login reading via OBDII: Audi A2 Audi A3 (CAN) up to 2007 !!! Audi A3 VDO/M73 up to 2003 (K) Audi A4 VDO (K) Audi A4 BOSCH (K) up to 2001 Audi A4 after 2000 - petrol engines >= 1.8 Audi A6 VDO (K) Audi A6 (CAN) petrol engines Audi Allroad (K) up to 2004 Audi Allroad (CAN) petrol engines Audi A8 up to 2001 Audi A8 from 2001 to 2002 2.5TDI Audi A8 (CAN) 2003+ petrol Audi TT (K) Audi Q7 petrol engines Seat Altea (CAN) Seat Cordoba after 1999 (K) Seat Ibiza (VDO) after 1999 (K) Seat Leon (K+CAN) Seat Toledo (K+CAN) Skoda Octavia Skoda Octavia II (CAN) Skoda Superb Skoda Roomster Skoda Scout (CAN) Skoda Fabia VW Bora VW Beetle VW Caddy (CAN) VW EOS (CAN) VW Golf4 VDO/Motometer/BOSCH RB VW Golf5 VDO (CAN) VW Crossgolf (CAN) VW Individual (CAN) VW Jetta (K+CAN) VW Passat B5 (K) B6(CAN) VW Polo5 VW Sharan after year 2000 VW T5 VW Phaeton petrol VW Touareg petrol VW Touaran VDO (CAN) PORSCHE Cayenne (CAN/K) Current version 3.0 covers VW/SEAT/SKODA (CAN) up to September 2006 while AUDI covered up to 2007
  3. Прочитал всё, но так и не нашел софта 3.6, Выложите плз,(Валера, знаю что есть)
  4. Че сказал, вроде помог я чтоль, если так - удачи :AllSmail (6):
  5. Пробуй Fiat Dukato 2.8 JTD_29F400 проба.rar
  6. С clip всё просто, главное чип и пин правильный чтоб. Original transponder PCF7936 PCF7946 (ID46)
  7. Есть 100% вариант для 29F200, вопросы в личку.
  8. Выкладывай дамп, эмуль не нужен будет.
  9. Лезь под машина там сгнив иммо провод у радиатора справа
  10. А в чем проблема то, там проводок под радиатором перетирает обычно(если не заводится)
  11. А чем ты его создавать будешь- напильником? для этого надо читалку- писалку иметь. на бензине Megamos 48, на дизеле-Tiris 4D
  12. говорят алго как на старых блау, перепробовал- не подходит. первую и последнюю цифры знаю, хотя бы еще одну. 95320.rar
  13. Вот дамп с такого же мерена, сравнивай. MC68705X32 eepr ML320.rar
  14. отвалился ключик, нужно править весь набор: сам ключ, оба проца в замке, и оба проца в защелке. если надо есть рабочий комплект, тока без моторного.
  15. Р1570 ошибка связи между ECM и DAS по CAN шине
  16. Без иммо - это не наш метод)))
  17. Думаю нет вариантов без иммо, в ключе texas 4D, делает танго по дампу иммо(TMS внутри)
  18. У танго тока один модуль для kessi 600 евра стоит!
  19. Сегодня сделаю дамп под твои ключи, скинь в личку мыло или асю.
  20. Значит когда он или новый хозяин авто потеряет ключ, на этом заработать не получится. Иммо ОФФ это не наш метод!!!
