borisp
Информация о borisp
  • День рождения 09.06.1983
    ford
Контакты
  • MSN
    sanjap
  • Сайт
    http://
  • ICQ
    Bosnia
  • Интересы
    frends end works
741 просмотр профиля
Достижения borisp
  1. Requires good dump for Daihatsu Move 0.8L 3 cylinder 1997 years Immo 89702-87211 93LC66 Ecu Denso 89560-87280 11200-4970 93c56 Thanks in advance
  2. I need code from dump Eprom ST95128 1Z0 035 161F Skoda Swing MP3 By Blaupunkt ST95128.rar
  3. Miles back to the desired value of the BSI and Dashboard but we remain chronicles the previous event when read ECU with the PPs2000
  4. borisp
    Peugeot 407 2006
    Can you help me about Peugeot 407 2006 how to delete the previous events, because when I come back kilometer they stay recorded. Thanks a lot
  5. Software done closing fap, fap pull content filters on exhaust branch and disconnect the two sensors before and after the sensor
  6. Handbrake and foot differ on the Golf 5 and Passat B6,, which has golf5 switch on the brake , Passat B6 on the cylinder. And therefore we can only help read a B6 Passat (2006 906 021lr 03g) with bdm100. Who had him read a bdm100????Only Passat B6
  7. i need orginal bdm file with extension .dim size about 604kb car is passat 1,9tdi 2006 year 03G 906 021 LR EDC16 U34 8959
  8. Urgently needed assistance to the Passat B6 1.9 TDI 105hp 2006 edc16u34 03g 906 021lr if somebody has read a BDM100 the entire contents, thanks in forward!!!!
  9. Here's the software that solves FAP and other filters http://www.4shared.com/file/4zsWjvzn/ECUSafe-FREE4ALL.html pass FREE4ALL
  10. borisp
    Fiat Bravo immo off
    Required immo off fiat bravo 2.0 20v 5 cylinder ECU Bosch 0261206068 hybrids fiat bravo 20 20v bravo immo off i need.rar
  11. Who have software solution to turn off the FAP filter flash motor electronics????
  12. Name:Miko hd id:DB0EE1AC-9A9A Thanks in advance
  13. borisp
    FIJATA PUNTA 12 8V 05
    Who you meeting with the ECU FIJATA from Punta-1.2 8V, 2005, the IAW 5AF P4 HW303 I'm interested in the engine, which can be noted that there are changes.
