Krkan
Krkan стал победителем дня 28 ноября 2024
Krkan имел наиболее популярный контент!
Информация о Krkan
    Srbija
668 просмотров профиля
Достижения Krkan
4
  1. Transfer one way from another forum: Step 1 Desolder the eeprom chip (ST 95160) and save the original content (just in case...) - see the picture attached. Step 2 Program the eeprom with the file in the attachment - remove.bin Note: in is NOT necesary to write protect the eeprom so you can use the original chip). Resolder the eeprom (solder all pins). Step3 When the car is started for the FIRST TIME with this eeprom content (the file inside of attachment) it will start ok. BUT, the interesting part come right now, after turning engine off... After take off the ignition, the ECU remains active for about 5 seconds (Power Latch) - it is also specified in service manual. It seems that MCU remain powered for another 5 secons...(for what?). You guess right...for reactivating the immo system. The ECU use power from permanent 12V power PIN. In this time (5 seconds) the MCU of the ECU try to "repair" the unmatched eeprom content with his internal image of the eeprom. So this is the reason of eeprom rewriting. In order to avoid this problem we need to REMOVE PERMANENT 12V POWER from ECU and conect it to after ignition 12V power. Step 4 Remove the PIN L4 - permanent 12V (or cut the wire from the connector - as you wish) and INSIDE ECU CONNECT PIN L4 with PIN M4 - 12v after ignition (see picture in the attachment). So from now when turn off the engine (take off the ignition) the ECU will remain completely unpowered - with this "new state" the MCU inside cannot modify the eeprom content so every start it is like first start for the MCU. Step 5 You can use some nail polish enamel to isolate the eeprom and some silicon to close the lid of the ECU. virgin.rar 5NR2.rar cho7_com_1082902978_495.rar
  2. If anyone can help me find the code.VW Rhapsody 1J0035156 VWZAZ4D6302894. Inside is 2X 24c08.Processor M38869FFAHP.Thanks in advance. Rhapsody.rar
  3. Citroen Xsara 2.0 HDI 2003 year. Siemens SID 801A.Eeprom 93C56 5WS40135C-T SID801immooff.rar
  4. How this device works? Where is joined on the ECU signal? What pins ECU must be connected?
  5. With Windows XP SP3, I could run the program, but I managed with SP1.
  6. Problem solved with this dump. Thank you to all those who tried to help. C180W202.rar
  7. Eeprom is firmly glued to plate.When i try removing eeprom twezers crush fifth pin. So that i could read dump.Panel before it worked well.
  8. I'm driving the car in the Mercedes service and say that the diagnosis can not create the configuration. Table is not appropriate for damp.
  9. Unfortunately none does match.I have a similar Mercedes C220 2000G 93c66.With this dump all work whell, but after 10 second goes out the mileage numbers and start to blink warning about lack of 2 liter oil.Not imposible to solve. MERSEDES_C220_2000G_93C66.rar
  10. Krkan
    Mercedes C class help
    If someone have dump for mercedes dash will help me a lot. W202 C180 2000. year. Petrol. Dash VDO 110. 008. 900/003 MB 202 540 60 48 Eeprom 93c66.
  11. Krkan
    BMW 730 1989
    Did someone changed the mileage BMW 730 from 1989 year.I'm not work older than 1992.Where is the recorder mileage. I have not noticed properly,except the old NEC procesor.
  12. If someone can help me with Blaupunkt CD changer IDC A09 BP9100. BP 910014673099 7 607 769 100 Damp from 24WC16 Thanks in advance IDCA09ORI.rar
