kan1975
Информация о kan1975
  • День рождения 03.12.1978
    ВАЗ 2110
Контакты
  • Сайт
    http://kan1975121@rambler.ru
    г.Сергиев Посад
  • Интересы
    Диагностика
388 просмотров профиля
Достижения kan1975
  1. Брал за 1390e + 80e за доставку. Отдам за 950e.
  2. Оригинальный сканер SMOK по Vag. Активированы доп опции по K-Line.Делает много чего !!!! Подробности по телефону. Могу продемонстрировать ! ЕЁ Цена 950+200+200 Euro . X-CAN opcja CAN Option1 NEC +24c32Read/Write KM, Read S-KEY by OBD, Load S-KEY, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option2 NEC +24c64Read/Write KM, Read S-KEY by OBD, Load S-KEY, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option3 VW VDO ...- 06/2006Read/Write KM, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option4 VW VDO 06/2006 -...Micronas Read/Write KM, Load S-Key, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option5 Visteon 95160/95320Read/Write KM, Read/Write EE, Read/Write Security Block,Read PIN, Erase ALL Errors Option6 AudiA3, TT 2007-...(Micronas CDC3217)Read/Write KM, Load S-KEY, Read/Write EE, Repair Flash, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option7 Golf 6 Magneti Marreli MC9s12XHZ512 2008-...Read/Write KM, Read/Write EE Option8 Golf 6 Magneti Marreli NECRead/Write KM, Read/Write EE, Read/Write Security Block Option9 AudiA3 (93c86) 2003-2006, A8 2003-2006 (93c86)Read/Write KM, Read EE, Read/Write Security Block, Read/PIN, Read VIN, Erase All Errors Option10 Audi A6, Q7 ...-2008Read/Write KM Option11 A6/Q7 2009-...Read/Write KM Option12 Touareg, Pantheon CAN 2007-...Read/Write KM, Read EE Option13 VW TFT NEC +24c64Read/Write KM, Read S-KEY by OBD, Load S-KEY, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option 14 A4/A5/Q5 2007-...Read/Write KM, Read EE Option15 A4/A5/Q5 2010-...Read KM, Read S-KEY OBD, Read EE, NEW KM (EEP) Option16 A4/A5 2012-...Read/Write KM Option17 A8 Fujitsu +93c86 2003...-...2006Read/Write KM, Read/Write EE, Erase All Errors Option18 A8 2006...-...2009Read/Write KM, Read/Write EE Option19 Golf 5 MM FujitsuRead/Write KM, Read EE Option20 A4/A5 lamp led codeRead/Write Settings, LED Enable/Disable, Control Lamp ON/OFF Option21 Audi A1 (NEC+c64) by OBDRead/Write KM, Read S-KEY by OBD, Load S-KEY, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN Option22 Polo/Fabia Jonson NEC+95320Read/Write KM, Read/Write EE Option 23 EC16 CANRead/Write KM, Read EE, Make ECU (EEP), Read PIN, Erase All Errors, Immo OFF/ON Option24 Audi A3, TT 2010-...Read/Write KM, Load S-KEY, Read/Write EE, Read/Write Security Block, Read PIN, Erase All Errors Option 25 VW UPRead/Write KM, Read/Write EE Option26 VW NEC+24C64 06/2012-...Read/Write KM, Read S-KEY by OBD, Load S-KEY, Read/Write EE, Read/Write Security Block, Read PIN, Read/Write VIN, Erase All Errors Option 27 DSGRead/Write KM II.Option BOSCH K-Line: VW RB8 2001 Audi RB4 ...-2002 AudiB8 2005-... Golf4/Bora RB8 VW Touareg v1 VW Touareg v2 Cayenne Seat Exeo EDC15 EDC16 III. Option All K-line VDO (c66,c86) , Motometer VW new bettel HC12 Sharan/Galaxy/Alhambra HC11 Passat 97 MM A3/A4/A6 MM Есть ещё Opel All Tool Opel All New New interface Opel All joins together the function of our two interfaces OpelEDC16 and OpelECU. In addition, is enriched about many functions. One of them is the possibility to read PIN directly by OBD and both joint of controllers. It operates OPEL Insignia and ASTRA IV: read and change KM by OBD. 10.06.2013 NEW option: Corsa C Z10XEP/Z12XEP -read PIN Linia K Bosch ME762 Z10XE,Z12XE (opel corsa,combo,astra)-read pin, reset ECU ,change VIN,read memory Delco Z16XE,Z14XE .Y17DT.....read pin, reset ECU ,change VIN, read memory Delco HFSI 2.0-2.4 Siemens Simtec MS70 (X18XE1,X20XEV, 1.8, 2.0 benzin astra vectra zafira),read pin, reset ECU , change VIN, read EEprom, write EEPROM Siemens Simtec MS71 (Z18XE,Z22XE 1.8, 2.0 benzin astra vectra zafira),read pin , reset ECU ,change VIN,read EEprom,write EEPROM, readKM, writeKM Delphi Z22SEread pin, reset ECU ,change VIN,read memory Bosch ME155 (astra G 1,2 Benzin)read pin, reset ECU ,change VIN,read memory PSG16 (Y22DTR,Y20DTH Vectra,Zafira Astra)read pin, reset ECU ,change VIN,read memory, read KM,write KM Linia CAN Bosch ME762 -read pin, reset ECU ,change VIN, read memory Delco MT35 (Z16XEP,Z16XE1 Astra,Vectra,Zafira)read pin, reset ECU ,change VIN,read EEPROM,read KM,write KM Delco HFSI22 (Z16XE Vectra C )read pin, reset ECU ,change VIN,read EEPROM,read KM,write KM PSG16 (Y22DTR,Y20DTH Vectra,Signum,Zafira Astra)read pin, reset ECU ,change VIN,read memory,read KM,write KM EDC16C9 (Z17DTH,Z17DTL,Z19DT Vectra,Signum,Zafira Astra)read pin, reset ECU ,change VIN,read memory,read KM,write KM EDC16C39 (Z17DTH,Z17DTL,Z19DT Vectra,Signum,Zafira Astra) reset ECU ,change VIN,read KM,write KM Simtec MS71.5 (Z18XE)read pin, reset ECU ,change VIN,read EEprom, write EEPROM,read KM, write KM Simtec MS71.6 (Z18XE)read pin, reset ECU ,change VIN,read EEprom,write EEPROM,read KM,write KM Simtec MS75 (Z18XER)read pin, reset ECU ,change VIN,read EEprom,write EEPROM,read KM,write KM Simtec MS81 (Z22YH)read pin, reset ECU ,change VIN,read EEprom,write EEPROM,read KM,write KM Denso 1.7 -read KM,write KM Сделаю скидку и (Договоримся)!!!! Opel All Tool ---- 23т.р
  3. Надо родной Star Diagnosis делать для Мерена, она больше даст информации.
  4. А на главном тормозном со стороны капота ничего похожего нет?
  5. Привет, ограничитель скорости меняется только MAN CATS 2 !!
