Tuner Опубликовано 26 ноября, 2010 Поделиться Опубликовано 26 ноября, 2010 Хочу себе приобрести данный аппарат, что скажете по поводу него? UDE MemTool Utilities - Tools for FLASH Memory Programming and OTP Memory Programming UDE MemTool is designed for On-Chip FLASH programming and On-Board FLASH / OTP programming with microcontroller hardware systems using C166, C166CBC, C166S-V2, XC166, XC2000, XE166, ST10, ST30, TriCore, PowerPC, ARM7, ARM9, ARM11, Cortex-M3, SH-2A derivatives. The debugging tool Universal Debug Engine (UDE) features the On-Chip FLASH programming or external FLASH / OTP EPROM programming directly from within the Debugging Environment via the UDE MemTool Add-In. Versions of MemTool for FLASH / OTP Memory Programming UDE MemTool Add-In .. is a part of the Universal Debug Engine (UDE) and allows the FLASH / OTP programming during the development cycle inside of UDE. MemTool observes the download path and runs the programming process when requested. UDE Standalone MemTool .. comes with a separate front-end interface as standalone tool outside of UDE. All programming functions are available also via standard COM automation interfaces. Using these interfaces, the features of MemTool may be integrated into automatic production and test systems or can be executed via scripts. General Features of FLASH / OTP Memory Programming * High-speed data communication by using the debug channel between target system and the debugging tool Universal Debug Engine based on the fast-PC6x or Access Device Communication Hardware * Automatic adaptation of data to be programmed to the smallest memory block size by automatic read operations * Easy-to-Use: FLASH programming is integrated in the debugger-to-target program download. * Transparent Erase Mode: previous bank read and bank erase simulate random access for non-bytewise erasable FLASH memories Functions of UDE MemTool UDE MemTool offers following functions (depending on the type of memory) * Erasing the entire memory module * Erasing selected sectors of the memory module * Loading Intel Hex and Motorola S-Record files * Programming all or selected portions of the file into the memory module * Comparing all or selected portions of the file to the current contents of the memory module * Read back and save-to-disk of the current memory content * Setting and Resetting the Chip/Sector Protection (On-Chip only) * Calculating CRC sums of sections * Watchdog handling for some derivatives. MemTool can handle more than one memory module on the target system and is only using On-Chip RAM for execution (IRAM; XRAM when available). MemTool supports the Single-Chip Reset Mode of the new SAB C16x derivatives. GangProgrammer for FLASH / OTP Memory Programming UDE MemTool can program FLASH memory devices simultaneously for saving time and optimizing the resource usage in production environments. The GangProgrammer utility administrates up to 8 programming stations. The used access devices (UAD2) can be connected to the host PC via USB, IEEE1394 or Ethernet interfaces, using hub devices. The targets are managed by separate target configurations. This allows a maximum of flexibility to the customer’s requirements. With a full-custom MemTool, even more advanced features can be included into MemTool. Operation Automatic activation when downloading an application in the debugger if write accesses onto the FLASH are required. In a dialog box all areas to be programmed are displayed. Programming may be started or cancelled manually. In the Transparent-Erase Mode, after editing a memory area in the debugger (e.g. in the memory window) the FLASH programming tool may be launched and the edited data can be burned into the memory using simulated bytewise programming. Supported Microcontroller with On-Chip FLASH / OTP Memories * XC161 CJ-16FF * XC164 CS-16FF * XC167 CI-16FF * XC2264, XC2267 * XC2285, XC2286, XC2287 * XE162 * XE164 * XE167 * SAB C161 CI/CS/JC/SI-32F * SAB C163 -16F * SAB C164 CI-8E * SAB C164 CH-8F * SAB C167 CR-16FM * SAB C167 CS-32F * ST10F163, ST10F166, ST10F167 * ST10F168 * ST10F169 * ST10F251, ST10F252 * ST10F269, ST10F296 * ST10F271, ST10F272 * ST10F273, ST10F275, ST10F276 * ST10F280, ST10F282 * ST30F771, ST30F772, ST30F774 * STR710, STR711, STR712 * STR730, STR731 * STR750 * ADuC7019, ADuC7020, ADuC7021, ADuC7022, ADuC7024, ADuC7025, ADuC7026, ADuC7027 * LPC2104, LPC2105, LPC2106 * LPC2114, LPC2119 * LPC2124, LPC2129, LPC2131 ,LPC2132, LPC2138 * LPC2141, LPC2142, LPC2144, LPC2146, LPC2148, LPC2194 * LPC2194 * LPC2212, LPC2214, LPC2292, LPC2294 * LPC2364, LPC2366, LPC2368, LPC2378 * LPC2468, LPC2470, LPC2478 * LPC2880, LP2880 * LPC2915, LPC2917, LPC2919 * AT91SAM7A1, AT91SAM7A2, AT91SAM7A3 * AT91SAM7S32, AT91SAM7S64, AT91SAM7S128, AT91SAM7256 * AT91FR40162 * STR910, STR911, STR912 * TMS470R1A64, TMS470R1A128, TMS470R1A256, TMS470R1A288, TMS470R1A384 * MAC71x1, MAC71x2, MAC71x4, MAC71x5, MAC71x6 * PowerPC MPC55xx, MPC56xx, SPC56x * TriCore TC1100, TC1115, TC1130 On-Chip/External FLASH * TriCore TC1161, TC1162, TC1163, TC1164, TC1165, TC1166 On-Chip/External FLASH * TriCore TC1775, TC1766, TC1796, TC1910, TC1912, TC1920 * TriCore TC1767, TC1797 * Latest XC166, XC2000, XE166, TriCore, PowerPC, ARM, SH-2A Derivative's On-Chip FLASH Supported External FLASH Memories of C166, ST10, XC166, XC2000, XE166, TriCore, PowerPC, ARM7, ARM9, ARM11, Cortex-M3, SH-2A derivatives * M29B xxx , M29C xxx , M29D xxx , M29F xxx , M29L xxx , M29W xxx Family and 100% compatible external FLASH * AT29C xxx * AT49B xxx * SST39VF xxx, SST39LF xxx * i28F xxx * M58BW xxx * TC58VFB xxx * I2C 24LC xx * further devices under preparation It is possible to extend the database of the supported external FLASH memories by the user. Please see the FAQ list of UDE. Communication between Host PC and Target System As communication channels ASC Bootstrap loader, CAN Bootstrap loader, CAN in combination with ASC Bootstrap loader and JTAG can be used. The standalone MemTool offers additionally the host-target communication via a standard RS232 host interface (COMx). Beside RS232 interface, the usage of the K-Line interface is possible. UDE Product ID Device MemTool /UAD2+ MemTool /UAD2 MemTool /fast-PC6x MemTool /ASC MemTool /EPP Target MCU communication interface Universal Access Device 2+ Universal Access Device 2 fast-PC6x Interface Card Host Serial RS232 Host Parallel EPP C16x, ST10, XC166, XC2000, XE166, TriCore, SPC56x, MPC55xx ASC Bootstrap Loader K-Line Interface ST10, XC166, XC2000, XE166, TriCore, SPC56x, MPC55xx(*) CAN Bootstrap Loader XC166, XC2000, XE166, TriCore, PowerPC, ARM, STR7, ST30 JTAG 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
Bruce Willis Опубликовано 27 ноября, 2010 Поделиться Опубликовано 27 ноября, 2010 Если хочешь им читать Tricore - то брось эту затею, не покатит. А прога что на скрине свободно качается и адаптор к ней это все го лишь логика на макс232 Ссылка на комментарий Поделиться на другие сайты Поделиться
avtoteh_dnepr Опубликовано 6 июня, 2011 Поделиться Опубликовано 6 июня, 2011 Если хочешь им читать Tricore - то брось эту затею, не покатит. А прога что на скрине свободно качается и адаптор к ней это все го лишь логика на макс232 Интересно, а ST10F280 зачитает? И если не сложно ссылочку на программу, пожайлуста. Ссылка на комментарий Поделиться на другие сайты Поделиться
DaemoNN Опубликовано 18 сентября, 2012 Поделиться Опубликовано 18 сентября, 2012 Ну как сказать вполне даж катит если парольчики знаешь! Правда прога называется Infineom memtool, работает через обычный К-Лайнер Ссылка на комментарий Поделиться на другие сайты Поделиться
