Volkswagen Transporter 2008 года
zuc
двиг AXC 86 лошади обьем 1896 куб/см
не заводится
Tuesday,10,May,2011,12:47:12:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 7H - VW Transporter
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H137140 Mileage: 99400km/61764miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 M HW: 028 101 185 6
Component: R4 1,9L EDC 6278
Shop #: WSC 02736 790 00000
VCID: 1E38DC26F6EDC3EC
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP.lbl
Part No SW: 7H0 907 379 R HW: 7H0 907 379 R
Component: ESP MK25E1 0104
Revision: 00H31001
Coding: 0001581
VCID: 448C4E4E38C1C93C
3 Faults Found
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 99401 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8449
Count: 8214
Count: 2303
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 99401 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 8448
Count: 8208
Count: 2303
01314 - Engine Control Module
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 8
Reset counter: 15
Mileage: 99401 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 8961
Count: 8194
Count: 2303
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 AD
Component: BORDNETZ SGVER 1.0 2101
Coding: 0000036
VCID: 74ECDE8E28E139BC
2 Faults Found
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
008 - Implausible Signal
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 3B AIRBAG VW51 0011
Coding: 13122
Shop #: WSC 02736
VCID: 2240E8D6C295E70C
No fault code found.
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 852 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 00103
Shop #: WSC 19411
VCID: 2A5000F6BAA53F4C
WV1ZZZ7HZ8H137140 VWZ7Z0H6412088
1 Fault Found
49-00 - No Communications
Address 18: Aux. Heat Labels: None
Part No: 7H0 819 008 R
Component: Standheizung 0209
Shop #: WSC 00000 000 00000
VCID: 3B7E35B2453FB6C4
3 Faults Found
01336 - Data Bus for Comfort System
01126 - Engine Speed Signal
02085 - Incorrect Control Module Installed
000 - -
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 02736
VCID: F0E4529EDCF9859C
2 Faults Found
01207 - Control Module for Auxiliary Heater (J364)
49-10 - No Communications - Intermittent
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7H5 919 044 J HW: 7H5 919 044 J
Component: J702 Dachdisplay 0500
Revision: 1010007S Serial number: 00000000063702
Coding: 0000002
VCID: 39722FBA4F0384D4
2 Faults Found
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 228
Mileage: 0 km
Time Indication: 0
Date: 2011.09.14
Time: 17:01:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 229
Mileage: 0 km
Time Indication: 0
Date: 2011.11.04
Time: 00:00:03
End ---------------------------------------------------------------------
по поводу ошибки CAN Gateway - 01314 - Engine Control Module
проверена проводка кан шины, т.к. шлюз видит абс и срс то эбу зачепил на кан абс. эбу не видно каншлюзом
на столе эбу выходт на связ что по к линии и что по кан
но эбу нивкакую не показывает текущие данные и ошбки что на столе что в мешине
Изменено пользователем zuc
Надо другой блок пробовать подкинуть. Можно еще попробывать считать флешку в нем чем нибудь. Хоть Галетой, хоть МППСом. И сравнить ее со стоковой. А что предшествовало этой поломке? Не был ли посажен аккумулятор? Не пытались ли завести машину веревкой с посаженой батареей? Если да, то мог слететь в блоке ЕЕPRОМ.
Такое ощущение , что смотрели халявным Вагкомом! По этому моторник не отображает дату , а там и висит отгадка на эту пролему с запуском! Были такие проблемы с Таурегом
VCDS Version: Release 10.6.0 не работает с этим моторным.
да именно этим и смотрел, при том китайским, завтра буду пробовать лаучем
да еще блок там EDC16 U31
Да нормальный ваг ком. Даже китайский. Лаунчем еще меньше увидит. Дата в ошибках есть, но в тех блоках которые связаны кан шиной. Которые связь потеряли с щитком приборов естественно даты не будет.
значит без кан шлюза блок не будет показывать дату
Пхоже блоку моторного кирдык пришел, а вот почему это уже у клиента выспрашивать.Про массы и питания не забудь.
блок отвечает на столе по кану и клинии, на мошине только по квп2000 но в обоих случаях определяются идентификаторы
может пенль его не распознает
где то слышал про прописку эбу в кан шлюз, вот как это зделать
Давай уже, предисторию рассказывай, а то переливаем из пустого в порожнее. Такие поломки просто так не случаются, сами по себе. Не надо ничего пописывать ни в какой кан шлюз. Все там уже давно прописывано. Твой компьютер через шнурок и кан шлюз обращается к блоку и ждет ответ определенное время. Ответа нету. Если бы оно было не прописано, то и обращения бы не было. А почему ты решил. что на столе есть связь по кан шине? Ну по к - линии еще понятно, а по кану как? Отключаешь К-линию и есть связь по кану?
С мотором на машине есть связь? Так и не понятно... ведь идентеры считались. Блоки данных видишь? Питания на мозг есть? Что рубит нештатная сигналка? А то были умельцы... хотя и сейчас есть, почему были? Что в блоках данных 125 в панели или авс или подух или 19 или 09?
Мотору побоку связи, кроме иммо, ессно - он заведётся и без связей.
Откинь разъём от головы, тот что на форсунки, - вяжись без него, вероятность мизерна, но всё-же...
история поломки: двиг стуканул, хозяева пытались всеравно его завести и заводили аж двумя аккумами, крутили вхлам просаженным аккумом
вот можики мотор перебрали
и вот теперь не заводиться, хотя утверджают (те кто перебирал мотор) что с десятого вклчения замка зажигания (загораются на панели свечи накаливания)и она заводиться
как определил что на столе блок выходит на связь по кану, да тупо отключил клинию
да иденты считчываются а блока данных нет
был фольс и у официалов, они тоже так с 10 раза машину завели и отдали что типа ГУД
сам пыталса завести таким дрочением замка зажигания - не получается
блок на связь выходит, но невидно блока данных, ошибок нету хоть все датчика отключи и после прокрутки стартером тоже ошибки не появляются в блоке
ВОПРОс: ЕСЛИ у блока слетело что в програмном обеспечинии (слет проши проши проца или еепромки) он будет показывать идентификаторы??????????????
а вот еще : пробовал лаучем показал ошибку в эбу по сажевому фильтру(не стирается), хотя тутже сорвал пару датчиков ноль имоций
Идентеры в ЕЕПРОМе сидят, а блоки данных и маски ошибок во флеше - больше похоже на проц или флешу. БДМ100 есть? Попробуй считать фулл и лийнуть другой для пробы, ну или любой подобный ЭДЦ кинуть опять-же на пробу. Можно и не пришивать для пробы.
значит по логике еепром целая а вот флеш и проц под вопросом
так там флеш не в проце лежит, вроде как так моторола
Там 95160 + МСР56Х... + флеха 58ХХкактотам на 4 гига, про которые пишут, что они сыпятся нурмально на этих блоках. Но всё это не есть факты. Ставь другой ЭДЦ, предварительно отключив форсы и лезь в мотор, на изменения в поведении глядеть. Так будет очень правильно!
  • Upvote 2
задачи ясны
СПАСИБО ОГРОМНОЕ ЗА ПОМОШЬ
буду искать другой едс
Я ж недавно решал похожую проблему. Фабию с посаженой батареей заводили веревкой. После этого слетели ключи, перестали читаться блоки даных, но иденты были. Проблема решилась заливкой новой эпромки в моторнике и привязкой ключей. Блок на эту машину будет стоить долларов 500-800. Поэтому надо его разобрать, считать БДМом фул процессора и эпромку. И посмотреть, что там потерлось. Стоковые прошивки на эту машину можно легко найти на этом форуме.
Изменено пользователем dracon
  • Upvote 1
