Ребят,есть у кого 2015R3 для легковых с активатором?
Это фейк, лучше 20,14,3,2 установите, или 2015,1
нужна программа с тазами. есть один таз,смотреть нечем его
Берите сканматик. Будут тазы, хоть людей не будете обманывать, да и сами видеть нормальные параметры.
ради одного таза мне купить сканматик? нет у меня потока на тазы и не будет.
Тазы для см2 это очень малая часть. Взять тот же Опель свежий.Вчера через Круз смотрел им инсигнию 14 г. Гляньте ,есть ли она в автокоме.Да и оп2 он заменяет на 95% при репроге и десяток дилерских марок, как адаптер работает.
Hello everyone,
I hope that someone speaks English.
I got a problem with my diagnostic tool and I cannot find any other thread with some much info about these tools.
I installed wow and delphi. After connecting, it informed me that I should update the firmware so I dit it. The firmware that was installed by wow was 1423. After that I was able to connect with my car and start diagnosis.
The problem is that it cannot communicate with ABS on my 2008 KIA Ceed.
I performs checks on all the other systems (including SRS), but on ABS wow reports: "Assemply does not respond"
I tried on a second car (Hyundai Accent 2001) and it performed all checks successfully.
I tried delphi after copying the firmware from wow folder to delphi. It was able to perform other checks but again it wasn't communicating with ABS. I also tried to update the firmware with 1430 but it didn't help.
While it performs the ABS scanning, the relay is clicking, the led switches between blue and green for a longer time period, which probably means that it doesn't get any response from the car.
What should I check on my board and/or my car? I am able to unsolder/solder parts but I don't know what to check on the boards.
I don't know how the scanner communicates with each system and what causing it to fail with ABS so I am not sure if this is a hardware, firmware, software issue or a problem with my car.
A few weeks ago the ABS light was on and that was the main reason I bought this board, so I would really like to find the issue and fix it. I visited a local garage, they replaced a part and they scanned and clear the fault code using a genuine tool with wow.
2014,3,2 финал или опен диаг с К лайном. из бюджетного если нет потока тазов
Hello everyone,
Good day)))
Which version of scanner do you use and which version of the program?
Good day)))
I tried delphi 2014R3 and WOW 5.00.8R2eng.
My board is this
Ребят,я прошу ссылку на программу у кого есть дайте пожалуйста. Зачем раздувать предложения по адаптерам и т.д? если есть дайте,нет так не пишите. Тазов вообще нет. кроме 1. На кой черт мне что-то покупать ради этого ведра?
Вам же написали - OpenDiag
опендиаг мобиле по елм327 читает и м74 , м75 , ме17.9.7 , м86 . только м75 , м86 и ме1797. платные по 100 руб. Остальные бесплатны . И блоки ABS по 100.
Изменено пользователем serg100orel
опендиаг  на оф сайте 4500 +обновы выходят . купите и пользуйтесь без ограничения , докупите рено хундай\киа , и нормальный шнурок. Хватает на основную массу машин .
Выводит одну и туже ошибку, пробовал на разных версиях, везде одно и тоже. jhbjh.JPG
