IMMO Polo
Hello.
I need some info if is posible to help.
I have an VW Polo 1.0 Benzin, year 2001, user lose all keys, she made a new blank key without immo chip, so i need to make immo off for this car.
Can someone give me some info and data files how to remove immo ?
Where is locate immo box on this car, what module have to remove ( immo /ecu/ dash ? ) and what type of memory reprogram?
I try with vag-can commander and vagtacho, cannot connect with any of this device in to the car immo, so i suppose need to remove immo box from the car, reprogram the memory...
Any info will be helpful. Thank you.
More easy to program a new chip, than remove immo. The chip cost is few $, and make it possible with a simple K-line adapter. Put the new chip into the blank key, read the login using vag-eprommer, and program the chip using vag-com 3112. It's easy.
Yes Danilius, i know, i don`t try yet with "vag-eprommer" to se if is possible to read the IMMO. As i say, i try vag-can commander 1.4, and vag-tacho 2.5 , none of this devices was able to log in to the car.
The owner of the car, already by a key without chip, she don`t wan`t to by another key, and she don`t need a key with chip, so i think immo off is the only solution.
Off topic. i also try few weeks ago to log in another polo, year 2005 , neither that car i was able to adapt a new key. what is the deal with external immo , and what SW i need to connect?
Thank you.
Thank you.
Immo off, it's only can do if there no any way to fix it. For Polo that way is very simple. Did you try to do a diagnostic for it? If yes, is it connecting? If no connection check the K-line in the car? Login is in the dashboard, read the chip in there and put dump here. We will calculate the login for you. And in advance always try to fix car and don't broke it. Immo off this is not solution, but unfortunetly sometimes it's only way to start a car with no expenses.
