Slavik k Опубликовано 13 ноября, 2012 Поделиться Опубликовано 13 ноября, 2012 (изменено) Software WinOLS 2.24 Программа WinOLS 2.24 Мощный редактор прошивок ЭБУ автомобилей включают в себя контрольки по EDC17, MED17, Mitsubishi L200, PajeroIV, Pajero SportII и установленными ЭБУ Denso с процессором SH7058 Download software http://letitbit.net/...S_2.26.rar.html Скачать софт http://depositfiles....files/qpafveodi WinOLS is an application, which is written especially to modify the memory contents of ECUs. It makes it easier to search and find maps, which can be named, displayed in several ways and be modified. All data and maps are stored in project files. These project files contain all information, which are gathered during the modification of the ECU. Additional data like customer name, license plate and pictures can be added. Modifications of maps can be stored as 'versions' and can be commented. Up to 200 versions of one original file are possible. All modified projects are shown in a list, which can be filtered and sorted. So it is easy to find an already modified project again. Overview: The display of raw data takes place in 2D graphic or hex/decimal dump. Automatic processor detection to decide between code and data areas. Functions to search for maps and to put them down on the map list makes efficient working a lot easier. A 3D preview window makes it easier to find maps Maps can be shown as 3D/2D chart or as a table. Automatic search of ECU and software numbers. You can select either English or German as the interface language and switch between these. The concept of the integrated checksum correction has been kept up. By using DLL files the algorithms were moved out of the main program and thus are independent of the version used. Im- and export of binary files, Intel and Motorola-Hexfiles. All types can be zipped, coded and have swapped lines or be sent directly by mail. The automatic map search finds maps and shows them in a list and also directly Preview-Window: The preview window can be freely moved and sized and shows the selection as 3d-map: Automatic checksums: Every checksum module (purchase separately) automatically recognises if it can be used and corrects the checksums immediately after every change. Even in real-time while the car is running. If you don't have the right module yet, the push of a button is enough and online all existing checksum modules will be tested for your project. This way you know for sure which module is the right one. Modules can be purchase online around the clock. You will receive your module within minutes. Free choice of colour: WinOLS has 3 predefined colour schemes and you can configure your own individual colours, of course. More features Original and version: For every project the original is stored permanently. Changes will be stored as version (the number of versions is not limited). Changes are displayed in colour and you can restore the original values any time. Multilevel undo: Up to 50 editing steps can be undone. Scripts for pros: If you work with similar cars, you can store the changes as scripts. This allows you to apply the changes for every new car within seconds. Automatic comments: You can enter comments for every project and every version. Further more they are automatically commented when you import or create new versions. Online project search: Our online-database can automatically fill in the fields like producer, chassis, etc. Several other fields, like Bosch number will even be filled in automatically when you're offline. Complete overview: The project overview shows all your projects in a configurable and searchable list. Within the fraction of a second, even if you have hundreds of projects. Versions: For every project you can create as many versions as like. The version over shows which maps are changed in which version. Open for other projects: WinOLS can import and export binary data, Intel- and Motorola-Hexfiles. Entire maps and the map list can be exported to Microsoft Excel. Maps can be ex and imported from a project. Accept changes: Copy the best changes from old projects. Even if the maps were moved to a different position, they will still be automatically recognized. Extensive help: Texts in the status bar, tool tips for the icons, Instructions for every dialog. WinOLS keeps you informed which every step. Furthermore you can download the entire documentation as PDF here. Many other features. Too many to list all of them here... Изменено 13 ноября, 2012 пользователем Slavik k 19 Ссылка на комментарий Поделиться на другие сайты Поделиться
Cilik Опубликовано 13 ноября, 2012 Поделиться Опубликовано 13 ноября, 2012 Спасибо.Все работает! Ссылка на комментарий Поделиться на другие сайты Поделиться
ellecctric Опубликовано 14 ноября, 2012 Поделиться Опубликовано 14 ноября, 2012 Земно кланяюсь добрый человек! Ссылка на комментарий Поделиться на другие сайты Поделиться
FinShark Опубликовано 16 ноября, 2012 Поделиться Опубликовано 16 ноября, 2012 Спасибо, хотя и имел другой вариант, но этот более удобен в установке. Ссылка на комментарий Поделиться на другие сайты Поделиться
вуц Опубликовано 20 ноября, 2012 Поделиться Опубликовано 20 ноября, 2012 Спасибо!весч полезная! плохо,что контрольку на msv80.0 не считает,а в остальном-гут! Ссылка на комментарий Поделиться на другие сайты Поделиться
wosmu Опубликовано 20 ноября, 2012 Поделиться Опубликовано 20 ноября, 2012 Спасибо, тока у меня не запускается. Ссылка на комментарий Поделиться на другие сайты Поделиться
хохол Опубликовано 20 ноября, 2012 Поделиться Опубликовано 20 ноября, 2012 Спасибо, запускается. Ссылка на комментарий Поделиться на другие сайты Поделиться
wosmu Опубликовано 21 ноября, 2012 Поделиться Опубликовано 21 ноября, 2012 Спасибо, запускается. Через Loader ? У меня "Starting Error". Ссылка на комментарий Поделиться на другие сайты Поделиться
vat Опубликовано 22 ноября, 2012 Поделиться Опубликовано 22 ноября, 2012 Спасибо, запускается. Ссылка на комментарий Поделиться на другие сайты Поделиться
Oleg_373 Опубликовано 22 ноября, 2012 Поделиться Опубликовано 22 ноября, 2012 привет ,а чего нод32 заорал что троян ? Ссылка на комментарий Поделиться на другие сайты Поделиться
FinShark Опубликовано 22 ноября, 2012 Поделиться Опубликовано 22 ноября, 2012 привет ,а чего нод32 заорал что троян ? Потому-что ломанный софт. Ссылка на комментарий Поделиться на другие сайты Поделиться
Evgenij_Ch Опубликовано 23 ноября, 2012 Поделиться Опубликовано 23 ноября, 2012 спасибо работает, чтоб "starting error" не появлялся нужно копировать всё в правильное место. C:\Program Files\EVC Ссылка на комментарий Поделиться на другие сайты Поделиться
drivehost Опубликовано 26 ноября, 2012 Поделиться Опубликовано 26 ноября, 2012 Спасибо! Ссылка на комментарий Поделиться на другие сайты Поделиться
domen Опубликовано 26 ноября, 2012 Поделиться Опубликовано 26 ноября, 2012 А контрольки считает? Ссылка на комментарий Поделиться на другие сайты Поделиться
ALEX Опубликовано 26 ноября, 2012 Поделиться Опубликовано 26 ноября, 2012 а не судьба прочитать что выше написано? Ссылка на комментарий Поделиться на другие сайты Поделиться
domen Опубликовано 26 ноября, 2012 Поделиться Опубликовано 26 ноября, 2012 Да судьба только у меня нет подсчета в проге она их не видит. Ссылка на комментарий Поделиться на другие сайты Поделиться
domen Опубликовано 26 ноября, 2012 Поделиться Опубликовано 26 ноября, 2012 Да судьба только у меня нет подсчета в проге она их не видит. Ура все заработало! Спасибо!!! Ссылка на комментарий Поделиться на другие сайты Поделиться
megaw Опубликовано 26 ноября, 2012 Поделиться Опубликовано 26 ноября, 2012 Ура все заработало! Спасибо!!! Человек ниоткуда, видимо правильно перекрестился Ссылка на комментарий Поделиться на другие сайты Поделиться
Oleg_373 Опубликовано 27 ноября, 2012 Поделиться Опубликовано 27 ноября, 2012 вот ссылка на дамосы (правда не вижу как сделатьих скрытым текстом-мож.админ поможет) с дружественного буржуйского форума https://rapidshare.com/files/1567043898/D_a_M_o_S.rar Ссылка на комментарий Поделиться на другие сайты Поделиться
ellecctric Опубликовано 27 ноября, 2012 Поделиться Опубликовано 27 ноября, 2012 файл не найден, скачивание не возможно, перезалей на другой ресурс Ссылка на комментарий Поделиться на другие сайты Поделиться
