OpenDiagMobile для Android
  • Ответов 6 тыс
И я нашёл :-) клапан адсорбера и рдв.
Send: 30430763
Receive: 70 43 07 63
Time: 18:57:20,722
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 31 00 00 01 01 00 00 00 FA 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:21,029
Send: 304301
Receive: 70 43 01 63
Time: 18:57:21,245
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 31 00 00 01 01 00 00 00 F6 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:21,553
Send: 2101
Time: 18:57:21,869
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 31 00 00 01 01 00 00 00 F7 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:22,151
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 31 00 00 01 01 00 00 00 F8 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:22,466
Send: 2101
Time: 18:57:22,756
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 31 00 00 01 01 00 00 00 FB 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:23,052
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 31 00 00 01 01 00 00 00 FC 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:23,362
Send: 30430764
Receive: 70 43 07 64
Time: 18:57:23,599
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 00 32 00 00 01 01 00 00 00 FA 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:23,886
Send: 304301
Receive: 70 43 01 64
Time: 18:57:24,114
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 00 32 00 00 01 01 00 00 00 F9 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:24,424
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 00 32 00 00 01 01 00 00 00 F8 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:24,728
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 00 32 00 00 01 01 00 00 00 F6 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:25,020
Send: 30430765
Receive: 70 43 07 65
Time: 18:57:25,266
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 32 00 00 01 01 00 00 00 F3 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:25,543
Send: 304301
Receive: 70 43 01 65
Time: 18:57:25,776
Send: 2101
Time: 18:57:26,076
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 32 00 00 01 01 00 00 00 F7 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:26,387
Send: 2101
Receive: 61 01 00 00 F6 1D 00 1E 00 00 00 04 00 2D 00 2D 00 00 00 00 00 00 00 00 00 20 F9 1E 80 32 00 00 01 01 00 00 00 F5 06 30 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 00 00 00 00 00 00 27 84 12
Time: 18:57:26,683
Send: 30430766
Receive: 70 43 07 66
Изменено пользователем zhekaf
Спасибо! Только, какой блок?
Микас 11. И с М75 так же  клапан адсорбера уходит в никуда..на 64 надо бы остановиться.
Микас 10.3 на днях проверю.
Понятно. Не доглядел за пределами! Завтра
Подправил. Выложу позже. Может ещё кто чего нароет :-)
с пробелами вообще тормоз. Начинает показывать данные которые прошли 2_3 секуны назад и уже не актуальны к тому моменту просмотра. Выключаю пробелы и допуски и всё норм. Допуски по необходимости, а потом выключаю. Так пашет!....
А последний тест как?
пока руки не дошли. Небольшой кризис и времени пока нет. А для парня про абс, вчера смотрел приору с блоком 17. 9. 7 правда, и там была какраз ошибка связанная с абс p0504. Неисправность датчика абс а-б или концевика(лягушка). Кстати, блок оределился без нареканий и косяков.
Я так и не понял! Торможение у всех осталось, на последней тестовой, при скролинге?
микас 10.3 программа вылетает при вводе с клавиатуры оборотов хх. и не работают пропуски воспламенения.
Обороты хх я уже исправил, а что значит не работают пропуски воспламенения? Прочерки? Завтра гляну. Лог не помешал бы. :-)
Прочерки. Лог с телефона никак не отправлялся.
От пропусков воспламенения у тебя блок отказывается :-( Подсунул твои логи под вер. вин, также прочерки! Не знаю чего сказать.
Учел такой вариант для микасов (отказ от параметра), чтобы переключаться не через информ или ошибки.
2.07.1.test5
Исправил всё найденное вами и мной. Добавил Микас 11 Е3 МТ и ЕТ (дроссель мех. и электр.) и допуски (пустые, в версии под виндовс тоже пусто).
Изменено пользователем sidrva
Такие Микасы проверить пока не могу, но c Микаc CR картина такая:
С адаптером AllPro ELM 1.1 программа работает.
С K-line работает, но до переключения с параметров в инфо и обратно. Наверно мешает повторный запрос на "код".
Ну и самое интересное, для простого ELM 1.5 и ELM 2.1 команду на "код" можно сократить до 8 байт? Эбу вроде дает ответ...
ATZ
ATZ
ELM327 v2.1
>atal
atal
OK
>ath1
ath1
OK
>ate0
ate0
OK
>atfi
BUS INIT: OK
>27 01 da 8f a0 e0 ae ab ec 31 34
84 F1 10 67 01 FC 5B 44
С K-line работает, но до переключения с параметров в инфо и обратно. Наверно мешает повторный запрос на "код".....
Даже не заглядывая в код, точно мешает! Завтра!
Про сократить! Знаешь такое изречение 'работает, не трожь...'? Думаю, так и есть! К тому же на CR у меня пока ни чего нет! Не занимался им!
Хотелось бы что бы Микасы 11 МТ и ЕТ с ELM работал, а не только по к-лайн. Просто Микас CR так же "запаролен" как и  Микас МТ и ЕТ.
А после сброса питания пускает вот так
ATZ
ELM327 v2.1
>atfi
atfi
BUS INIT: OK
>27 02 00 00 00 00
27 02 00 00 00 00
67 02 34
>2107
2107
61 07 00 00 24 EC 0A EC 00 00 1F 03 80 34 80 34 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 01 01 00 00 00 B4 0A 50 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 82 A5 0F
ATZ
ELM327 v2.1
>atfi
atfi
BUS INIT: OK
>27 02 00 00 00 00
27 02 00 00 00 00
67 02 34
>2107
2107
Думаю, что с МТ и ЕТ такое не прокатит, да и не со всеми CR! В общем надо проверять!
P/S Вообще гдета читал о подстановках нулей и срабатывает! Не помню про какой блок! Может он и есть!
Предположу, что с МТ и ЕТ автоопределение не работает, если с СR не срабатывает, без 21b3.
ATZ
ATZ
ELM327 v2.1
>atfi
atfi
BUS INIT: OK
>1a91
1a91
7F 1A 33
>1a9a
1a9a
7F 1A 33
>21b3
21b3
61 B3 35 38 31 2E 33 37 36 33 30 30 30 2D 30 35 20
Вот это я не знаю. Логов нет ни каких!
Без кода эбу не отдает данные о себе.
А если бы после инициализации была команда 21b3, то программа бы уже знала, что подключен микас мт,ет или сr.
Когда в программе ещё не было микаса 11е2, то программа выводила, что подключенн микас 11е2, но программе он не известен.
