jackhoo Опубликовано 14 июня, 2014 Поделиться Опубликовано 14 июня, 2014 http://www.careucar.com/wholesale/renault-can-clip-diagnostic-interface-a.html 2014 Best Quality Renault CAN Clip OBD2 Diagnostic Interface This is best quality one. More stable on diagnosis. It's very simple to diagnose a vehicle using Renault CAN Clip Diagnostic Interface: just select the vehicle make, enter the V.I.N. and press ENTER. Renault new update software version: V139 Renault Clip Functions: 1. See all the information relating to the vehicle 2. Computer test 3. Automatic test of all computers 4. Reprogramming 5. Airbag test 6. Scan tool (OBD tests) 7. Base Doc (access to Technical Notes) 8. Physical measurements 9. Antipollution 10. Multimeter Renault Can Clip V139 Supported Languages: English,German,Brazil,Denish,Spanish,Finnish,French,Italian,Norwegian,Dutch,Portuguese,Romania,Swedish. Packing Including: 1pc x Renault can clip Main unit 1pc x OBDII Cable 1pc x Renault 12pin Cable 1pc x USB Cable 1pc x CD software 32CM*19CM*9CM Renault CAN Clip Registration steps: 1. After finish Installation, DO NOT run your CLiP! 2. Copy the RSRwin.ext to C:\CLIP_X91\Lib\Application\ 3. Then run your CLIP, choose "Register me now" and in the next Windows, please select "NO"! 4. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF Ссылка на комментарий Поделиться на другие сайты Поделиться
