Программатор одометров от SMOK
Продам оборудование по корректировке одометров для Ford и Reno чисто польское не китай, отдам по 12 тыс. каждый. Покупал всё вместе за 1000 евро. Шнурок Рено с дополнением можно делать меган 3, Лагуну и Fluence не только в панели но и ABS скидывает через OBD 2. Вот ссылка на сайт
http://www.smok.com....rta&kategoria=1
Для Рено
Fiat Punto 99-2002 Motorola Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Punto 99-2002 NEC Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Punto 2002-2006 NEC Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Grande Punto Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Grande Punto Lift Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Punto EVO Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Doblo 99-2006 Motorola Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Doblo 99-2006 NEC Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Panda 2004-2007 95040 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Panda 2004-2007 95080 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Idea 2004-2007 95040 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Idea 2004-2007 95080 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Croma 2005-2007 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Bravo 2005-2007 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Ducato 2006...2011 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Ducato 2011-... Read/Write KM, Read/Reset Insp., Erase Errors
Fiat 500 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat 500L Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Linea 95080 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Stillo HC12D60 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Stillo HCS12 Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Qubo Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Fiorino Read/Write KM, Read/Reset Insp., Erase Errors
Fiat Bipper Read/Write KM, Read/Reset Insp., Erase Errors
Renault Megane II 93c56 Read/Write KM, Read/Write EE
Renault Clio III 24c04 Read/Write KM, Read/Write EE
Renault Megane II 93c66 Read/Write KM, Read/Write EE
Renault Megane II 24c04 Read/Write KM, Read/Write EE
Reanult Master III 93c76 Read/Write KM, Read/Write EE
Renault Fluence 95160 Read/Write KM, Read/Write EE
Renault Laguna III (przed korekcja nalezy ustawic KM w module ABS lub zalozyc CAN Bloker) Read/Write KM, Read/Write EE, Read/Write Flash
Renault Megane III VDO (przed korekcja nalezy ustawic KM w module ABS lub zalozyc CAN Bloker) Read/Write KM, Read/Write EE, Read/Write Flash
Renault Megane III Jonson Control (przed korekcja nalezy ustawic KM w module ABS lub zalozyc CAN Bloker) Read/Write KM, Read/Write EE, Read/Write Flash
Renault Trafic III 93c76 Read/Write KM, Read/Write EE
Kango III 93c76 Read/Write KM, Read/Write EE
Reanult Kaleos 95160 Read/Write KM, Read/Write EE
Renault Laguna II HC12 Write KM
OPTION 2. Blockade ABS by OBD Laguna/Megane III
Fiat-Reanult Tooloption blockadeKMin ABSby OBD Laguna 3, Megane 3(2008-....). Not need CAN BLOKER !!!
Renault Laguna ABS (blockade ABS by OBD)
Renault Megane ABS (blockade ABS by OBD)
Renault Fluence ABS (blockade ABS by OBD)
Для фордов
OPTION 1.Supported models Ford:
Transit 2012-...Read/Write KM (NEW from 09.09.2014)
Kuga 2013-... Read/Write KM (NEW from 04.09.2014)
Fiesta 2013-... Read/Write KM, Read/Write EEprom ( NEW from 04.09.2014)
Focus ...-2007:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
C-Max ...-2007:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Fiesta 2005-... :Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
S-Max 1/2 FIS:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Mondeo 1/2 FIS:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
C-Max'07..-..'08 1/2 FIS:ReadKm, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Focus'07..-..'08 1/2 FIS:ReadKm, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Galaxy 1/2 FIS:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
S-Max, Mondeo Full FIS:ReadKm, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Focus 2008-... :Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
C-Max 2008-... :Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Fiesta 2008-... :Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
S-Max 2008-... :Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Kuga:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Mondeo Color 24c16:Read/Write Km, , Clear All Errors
Focus, C-max NEC:Read/Write Km, Clear All Errors
Mondeo 2010 Full FIS:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Conect HCS12:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
Mondeo 2010 1/2 FIS:Read Km, Write Km UP, Read/Write EE, Set 0 Km, Clear All Errors
AirBag Crash CAN 2005-2008:Read Errors, Erase Errors, Erase Crash
Engine ECU:Read Km
я так подозреваю что флюенс делает до 12 года и то не все...
ABS на новом логане можно делать на новом оборудовании там одно обновление стоит 200 евро. Если не трудно зайдите на сайт и ознакомьтесь.
http://www.smok.com.pl/index.php?lang=en&id=oferta&kategoria=1&produkt=20
На сайте поддеожка нового железа. Эти шнурочки уже неподдерживаются. Что есть в этизх шнурочках, то есть и туда даже за деньги не добавишь. Прошу извенения у автора за антирекламу. Люди должны знать что покупают и к чему готовится. А так м=Смоковские шнурочки работают на все 100
А я и не говорю что они обновляются. Если бы они обновлялись они бы стоили на порядок дороже. Но что ими можно делать на данный момент тоже актуально.
